Shimano Compatibilidade - Transmissão - Estrada (Tabela)
johny32
Bicycling - Shimano Road Bike Parts Compatibility - Tables
Feb., 2015
Shimano compatibility charts come in handy for assembling your bicycle, planning purchases, or troubleshooting. This page of Tables is a compilation of Shimano specifications not found in the compatibility charts alone. The source of these data is Shimano's product manuals.
Contents
Shimano Compatibility Charts Main Page
Derailer Capacity Specification - Cogset Chooser table
Cycling Components Store
Notes on Compatibility of Components
Real World Reports
Ask the Chart Monkey - find compatible parts quickly
Derailer Capacity
Source: Shimano specifications.
Model Speeds total capacity low sprocket top sprocket Front chainwheel
max (min) min (max) tooth difference
Dura Ace:
RD 9000 (SS) 11sp -double 33 or less 28(23) 11(14) 16
RD 9070 (SS) 11sp -double 33 or less 28(23) 11(14) 16
Ultegra:
RD 6800 (SS) 11sp -double 33 or less 28(23) 11(14) 16
RD 6800 (GS) 11sp -double 37 or less 32(28) 11(12) 16
RD 6870 (SS) 11sp -double 33 or less 28(23) 11(14) 16
RD 6870 (GS) 11sp -double 37 or less 32(28) 11(12) 16
RD 5800 (SS) 11sp -double 33 or less 28(23) 11(14) 16
RD 5800 (GS) 11sp -double 37 or less 32(28) 11(12) 16
Dura Ace:
RD 7900 (SS) 10sp -double 33 or less 28 11 16
RD 7970 (Di2) 10sp -double 32 or less 27 11 16
Ultegra:
RD 6770 (SS) 10sp -double 33 or less 28(23) 11(12) 16
RD 6700 (SS) 10sp -double 33 or less 28 11 16
RD 6700 (GS) 10sp -triple 39 or less 28 11 22
RD 6700A (SS) 10sp -double 34 or less 30(23) 11(15) 16
RD 6700A (GS) 10sp -triple 40 or less 30(23) 11(14) 22
105:
RD 5700 (SS) 10sp -double 34 or less 30 11 16
RD 5700 (GS) 10sp -triple 39 or less 30 11 22
RD 5701 (SS) 10sp -double 34 or less 30(25) 11(14) 16
RD 5701 (GS) 10sp -triple 40 or less 30(25) 11(14) 22
RD 5701 (GS) 10sp -double 37 or less 32(27) 11(12) 16
Tiagra:
RD 4600 (SS) 10sp -double 34 or less 30 11 16
RD 4600 (GS) 10sp -triple 39 or less 30 11 22
RD 4601 (SS) 10sp -double 34 or less 30 11 16
RD 4601 (GS) 10sp -triple 40 or less 30 11 22
RD 4601 (GS) 10sp -double 37 or less 32(27) 11(12) 16
Dura Ace:
RD 7800 (SS) 10sp -double 29 or less 27 11 14
RD 7800 (GS) 10sp -triple 37 or less 27 11 22
Ultegra:
RD 6600 (SS) 10sp -double 29 or less 27 11 14
RD 6600 (GS) 10sp -triple 37 or less 27 11 22
105:
RD 5600 (SS) 10sp -double 29 or less 27 11 16
RD 5600 (GS) 10sp -triple 37 or less 27 11 22
Dura Ace:
RD 7700 (SS) 9sp -double 26 or less 26 11 14
Ultegra:
RD 6500 (SS) 9sp -double 29 or less 28 11 14
RD 6501 (GS) 9sp -triple 37 or less 27 11 22
105:
RD 5501 (SS) 9sp -double 29 or less 27 11 14
RD 5501 (GS) 9sp -triple 37 or less 27 11 22
in http://www.celebrazio.net/bicycling/shimano/compatibility_tables.html
Eita, já lá vão uns anos desde o 1o e único post neste tópico... Mas cá estou eu!
A compra não seria para agora, mas despertou-me a curiosidade com esta resposta nesse tópico.
Então é o seguinte:
Tenho transmissão 10v, penso eu que é tudo shimano 105 5500.
E a ideia era fazer upgrade para:
Cassete 10v 12-32, 12-30, ou 12-28
Pedaleiro 52-36
Perguntas:
Será tudo isso compatível com as manetes que tenho?
Em relação ao movimento pedaleiro, o atual é assim. Qual teria que comprar?
Eu não percebo nada de compatibilidades e estive a tentar perceber se a evolução é possível ou não.
Bolas, esqueci-me de adicionar:
O desviador atual é shimano 105 e penso que já dá para 11v, mas não garanto.
O upgrade seria para Shimano Tiagra 4700 por forma a ter compatibilidade com 10v, e por ser mais barato pois a bicicleta já é antiga.
A ideia começa porque tenho atualmente 50-36 x 11-25 e por vezes não se justifica e seria boa ideia colocar uma cassete com andamentos mais leves.
As especificações originais da bike, aqui
Eu devo estar a ver mal a coisa, só pode
Se tens pedaleiro com 50x36 porque não mudar o 36 para 34
Mudas a cassete, qualquer coisa 30 ou 32 e se o desviador não der existe uma pecinha de 5 euros que o estica
É meter corrente nova e dá para muito
Como eu costumo dizer, nunca senti falta de maior prato, já de maior cassete.......... já senti, ainda este fim de semana senti
Caso insistas na troca, é juntar a massaroca e indo procurando por essa net fora, volta e meia aparece alguns conjuntos 105 de 11 a bom preço
Lembrei-me disso mesmo @GuilhermeOliveira, de mudar o 36 para 34. Mas acredito que a mudança não será nada por aí além porque continuo com o 25 atrás.
A ideia era mesmo mudar a cassete, mas não sei que problemas posso ter em compatibilidade especialmente se o meu desviador não chegar para os 30.
Eu ia apontar para uma cassete 11-30, mas como fui alertado para eventuais problemas de compatibilidade decidi checkar primeiro
Eu disse trocar o prato, cassete, corrente e caso o teu desviador não dê podes sempre meter a tal pechinha
Essa peça só funciona corretamente com desviadores de caixa média ou longa.
Vê a tabela de compatibilidades da shimano. O 4700 não é compatível com os grupos de 10v anteriores.
Se tudo está a trabalhar bem agora, não estou a ver o problema de meter um prato ligeiramente mais pequeno e uma cassete com carreto maior mas com as mesmas velocidades, caso ultrapasses o limite do desviador só tens de meter o extensor
Eu tenho um grupo de 8vel Shimano 600tricolor a trabalhar com extensor por causa da cassete ser maior, já tive pedaleira compacta comprada, mas custa lá meter uma diferente do grupo, só por causa da estética
Cassete de 27 ou 28 atrás e se for preciso metes o 34 à frente.
12-28 não conheço, na specialized cheguei a ter 12-27.
Como disse: vê a tabela de compatibilidades da shimano (google it) e vê as opções que tens para a transmissão.
Se não fosses tu a alertares para possíveis incompatibilidades, iria estar a caminhar no sentido errado!
Vou ter que ver quando estiver no computador, mas obrigado!
36-28 ou mesmo 34-28 não me "choca", pode é continuar a ser curto, mas claro que mais leve que um 25 :eek::D
Então para eu perceber:
Esta cassete não consigo utilizar porque é tiagra 4700
https://www.probikeshop.pt/cassete-shimano-10v-tiagra-4700/115696.html
Mas esta já podia, certo?
https://www.bike-components.de/en/Shimano/105-CS-5700-10-speed-Cassette-p24994/
Podes montar todas as que listaste. As incompatibilidades a que se referia a Carolina são a nível de desviadores e manetes. Qualquer cassete de 10v (da norma shimano/sram até 11v) pode ser montada onde já tens uma cassete de 10v, quer tenhas 105 ou tiagra, (ou outro grupo de 10v fora campagnolo).
Ahhhh ok. Eu ainda pensei que depois se traduzisse na cassete porque podia estar relacionado.
Ok, então entendi.
12-28 seria no meu caso a cassete a colocar.
A ideia de trocar (quase) tudo era juntar tudo em um:
Mais recente
Estava mais à vontade com uma cassete 30 ou 32
Assim sendo talvez não seja tão fácil assim.
Terei que ver se o novo shimano 105 é compatível com o antigo.
Assim, mantinha as manetes, trocava o desviador sem problemas de compatibilidade e tinha a cassete 30 ou 32
Ok, então entendi.
Mais recente
O 105 de 10v não é compatível com o 105 de 11v. Ainda não consegui perceber qual é o teu problema... cassete de 30 dentes não resolve o teu problema?
Se é para trocar quase tudo, mete o 4700 completo. Problema resolvido. (Estou a supor que nas rodas tens a limitação de 10v.)
@joseruivo
É isto mesmo explicado abaixo pelo @cconst
Eu não me importava de ter cassete 30 ou até 32, mas com o desviador atual não dá.
Pensei em arranjar um desviador tiagra 4700, mas não é compatível como visto.
Penso agora num desviador 105, mas devido às manetes, não sei ao certo qual poderia colocar.
@joseruivo parece-me que o problema é a compatibilidade entre a cassete de 30 e o actual desviador dele (possivelmente está limitado aos 28).
Daí o @elchocollat perguntar pela compatibildiade do novo 105, pois para colocar a cassete de 30 precisaria de um Long Cage...
Assim já fica demasiado caro... :confused:
Provavelmente vou meter cassete 28 e aguento-me na mesma... Mas já que estava a pensar nisto, ao menos ficava esclarecido das dúvidas.
